<font color='#000000'>Hi
Take a DVD/CD transport. No DAC, just three connections:
- DVI for video;
- Toslink and digital audio for home theater;
- IEEE-1394 for multi-channel audio.
That is all you need for a high-end receiver.
I am sure that the circuit in the Denon AVR-5803 for processing DAC is as good as the one in their 5900.
Same with Yamaha RX-Z9.
Save 1000$ on the DVD player, put it on the receiver: et voila.
The only problem, this dream DVD (cheap, cheap, cheap) does not exist. The manufacturer who does that will change the paradigm in the industry. If we do enough noise, they will listen... Integra DTR-10.5 seems to go in that direction.</font>
