Why Do Some DVD's Play Louder Than Others??
Team_Canada
Can anyone tell me why some DVD's play louder than others??
For example, Saving Private Ryan DTS is very loud, great sound effects movie. I had my system at -14db and that was almost too loud. I just watched Vertical Limit which is also a loud movie with great sound effects but was able to go up to -10db and probably could have gone up a couple more??
Does the recording format have anything to do with this, meaning DD, DD EX, DD ES, DTS, etc.??
Just curious. Thanks in advance for the replies!!
Jack Hammer
Jack Hammer
Yeah, why is that?
Some movies (Master & Commander) I play around -25 and it is very loud. Others (Tears of the Sun, Predator) I play around -10 and it is still not that loud.
I'm guessing it has to do with the sound engineer?
Jeff
racquetman
racquetman
Dynamic range. You could have a soundtrack like many CDs (not all obviously), where everything is overly compressed, and then the quiet stuff would be louder and the loud stuff would be quieter. None of us want that.
If you do a search, you'll also notice quite a few threads about how DTS soundtracks are louder and therefore are perceived as sounding better.
The fact of the matter is that not all DVDs come from the same place. There are no set standards in place saying that a DVD soundtrack has to conform to certain criteria or whatever. Studios and whoever else is involved in transferring a movie soundtrack to DVD all go about it differently. You notice that with different editions of DVDs you get different soundtracks a lot of time. I'm no expert on any of this stuff obviously, but without standards in place, you are going to get varying results (some good, some bad).
My recommendation is before you buy a DVD, do some searching for sites that rate the DVD and its soundtracks (if you care that much) - thedigitalbits.com is good for this, but there are many others.
Also, get used to using the channel level trims on your receiver. Since every movie is different, you may need to adjust things slightly different for every movie if you are picky about the presentation (like me :) ).
Team_Canada
Thanks guys, DTS does sound louder and as far as I am concerned sounds better. All action and sci-fi movies should be in DTS. I try to by DTS versions whenever possible. I have not had too many problems with movies but when I watched Vertical Limit last night, I noticed a huge difference in volume level compared to Saving Private Ryan, mind you my copy of Vertical Limit is not the DTS version. War Of The Worlds was very loud as well.
I will check out the website you provided alandamp.
edwelly
edwelly
I read where DTS discs are recorded are higher/louder level than Dolby. I think this is what you are hearing...
