AV electronics, even the simplest of stereo receivers, have thousands of individual electronic devices pieced together onto one circuit board. If you consider each electronic device, solder joint, wiring connection, etc. to be a potential “point of failure” the odds of failure should be staggeringly high. But, relatively few amps/receivers/DACs ever fail! So, one way to look at it is, the manufacturers of electronics have succeeded in a staggering achievement in being able to reduce the odds of failure to “parts per thousand” for the receiver or amplifier as a whole. When one adds physical considerations like VFD, knobs, buttons, etc. and soft failure points like thousands of lines of software to drive electronics, the achievement seems nothing short of miraculous. In this light, when you consider a company like Bryston, which gives a 20 year warranty on all their products, one cannot help but respect their uncompromising build quality.
By contrast, a speaker is so "simple" (in context of "potential points of failure"), it almost seems absurd that they do not come with lifetime warranties.
