yeah I ran 4-14 wire and they are connected the same way on both ends. positive to positive negative to negative. here's the thing that's so odd, when I turn the balance all left or all right it sounds better. It has base its not garbled and weak. when I turn it back to mix the left and right channel equally it goes back to sounding like its submerged or its almost sounds like its one of those weird vocal effect synthesizers rappers like t-pain use. lol
any other ideas?
You're gonna have to use a reference I can deal with. Did you reverse the wires for one speaker at the volume control? Make sure the output configuration is the same as the way it goes into the control. If it's really echoing, it sounds like you have the speaker connected to both positives and the negatives are connected to each other, but not to the amp's output negatives. Post some photos for:
Amplifier's speaker terminals, showing the speaker wire colors
Volume control terminals, showing the terminations and colors
Speaker terminals, showing wire colors and if you can, the lead going to the crossover.
If you want to test the speaker to make sure the voice coils and terminals are wired correctly, disconnect the speaker wires and cut two pieces or wire from scrap, so you'll have a way to connect a AA battery. You don't want to hold the wires on the battery for long, you just want to see which way the cone moves. With the Battery + on the + wire, the cone should move outward for both voice coils. Don't worry about the tweeters- they don't matter for this test. If you see one move inward, either replace it or wire it so it sounds correct.
The first logical step should be to try another speaker.
