Who makes the best main speakers
perryg114
Who makes the best main speakers for music $1000 a pair?
Perry
annunaki
annunaki
Moderator
The term "best" is quite subjective. There really is no "best" speaker. However, you can find a speaker that suits your personal likes, "the best". The "best" way to do that, is to listen to many different speakers in your price range, with music you are familiar with. Take notes on your likes and dislikes from those you've listed to, and make a decision. Make sure to use the same source music for all the speakers as well.
Some brands I would check out would be: B&W, Axiom, Monitor Audio, PSB, Paradigm, Energy, Mirage, and Phase Technology
BJP
BJP
Perry
Perry, give the Axiom M80ti's or M60ti's a shot. Axiom has a 30 day money back guarantee. The 80 is a bit over your budget though and you will need a amp capable of driving 4 ohm speakers. I think you will be very happy with the M80ti's.
Buckeyefan 1
Buckeyefan 1
Perry
Perry,
If you plan on powering them with your Pioneer 1014, I'd recommend some higher spl (>91), 8ohm speakers. If you plan on adding a separate amp, that will open a lot of doors.
agarwalro
agarwalro
I would'nt give up my Axiom's
I have has the Axiom M60ti's for a couple of months. Man these speakers shake the walls. I am also running a 5.0 (no sub) setup comprised of Axiom speakers, I highly recommend this company. The 30 day money back guarantee is there, but only a less informed person would want to return these.
AXIOM ******* ROCKS
Please try to keep the language clean. There are other "sentence enhancers" available. -Thanks Admin.
snickelfritz
snickelfritz
Depends greatly on the type of music.
For example, vintage rock sounds pretty good on most speakers, but intimate recordings of acoustical instruments and vocals require a more refined midrange and treble response and accurate imaging.
Audition the Paradigm Studio20; this is a very well designed stand-mount, notable for it's natural reproduction of music and high quality construction.
The 1014 doesn't have the muscle to handle a full compliment of Studios, IMO. It would do fine with external amplification for the mains though. No offense, but to be honest, just about any speaker at $1K/pr is probably going to push the limits of the 1014 and I would say it is probably not a good idea without external amplification.
furrycute
furrycute
For your budget, get a pair of small floorstanders.
Paradigm, Energery, Infinity (yes, I love my Infinity kappas), etc.
MacManNM
MacManNM
Perry
None of them sound decent unless you have a sub with the setup. If you could get an external amp for your system you could pick up a pair of Polk RTI 10 or 12's. They are a good all around speaker (rock, country, jazz, etc). I would stay away from anything with woofer sizes less than 6.5".
RLA
RLA
Hello
The Klipsch Reference Series and the 1014 will tear the house down
The 1014 will drive even the Flagship Referece Series with no problems.
102dB 1 watt 1 meter does help a bit ;)
And yes I love the sound of horns with music :)
You'll have to go listen to Klipsch and decide for yourself :) Klipsch should work thanks to their extreme sensitivity, but they are sort of a love it or hate it kind of speaker.
droeses58
droeses58
I have a pair of Klipsch reference in-walls that were extremely well driven by my Pioneer 814 they sounded very nice. I have since went to an h/k and they sound even better :)
However, I must agree with j_garcia lots of people dont like the use of horns in speakers, I love it though
L
littleb
AXIOM ******* ROCKS
I would have to agree with this, AXIOM definitely ROCKS! And I don't even have the M60s.
furrycute
furrycute
I think Infinity makes the best main speakers.
Infinity once made a model that literally weighed several tons, that came with huge amps that power the built in subs (12, 15,... can't remember the exact number). Yep, you literally needed a moving company to move them and some pretty damned hard reinforced concrete floor to enjoy them at home.
If memory serves, one of the founders of the original Infinity left the company and later founded Genesis, and tried to make an ever bigger pair of main speakers. I think he actually made them.
Anyway, those Infinity monsters sounded AWESOME. When crancked up, they can literally blow you away (well, almost).
And oh, you need some serious dedicated power to feed those puppies. They'll fry your average househould electrical sockets. :D
ht_addict
ht_addict
Paradigm Studio 20 get excellent reviews. Here's a part of the review from Audioholics.
The 20's Sound
I was floored, absolutely floored from the very first note. What clarity. What depth. What sublimity! What a wanton freedom from anything which could be construed as objectionable.
In my acoustically treated room there was none of the "spice" which so many (including myself) have over the years reported on Paradigm speakers, further lending credibility to my theory that Paradigm speakers are properly neutral and that, by and large, it is our listening rooms that cause much of our system's tonality.
The critical midrange was remarkably unbiased, allowing such elements as female vocals a level of believability that left me breathless. Albums I remembered as being less than stellar in their sound now struck me as wholly transparent. Harmonies previously buried in the mix were now discernable without as much effort. "Revealing" does not seem strong enough a word.
For the majority of the review, we ran the 20s full range. On several occasions I had to verify, and re-verify, that the configuration was correct, i.e., that the subwoofer was off. Flabbergasted, I dug out the sine wave sweeps and nearly wept openly as this relatively small speaker reached down with credibility to the 30s, defying the preconceived notions of what can be squeezed from a 7" driver. Yes, the bass is that deep, that latent. In fact, this is the best bass, both in terms of quality and quantity, that I have ever hear from a "bookshelf" speaker, including a few models costing more than twice as much. By and large, in the near field roll, I could be perfectly satisfied without a subwoofer. In larger rooms of course (or for irresponsible playback levels) some bottom end support is warranted.
For this one would ideally pass the output of a THX controller through a secondary 12dB/Oct filter, resulting in a 24/24 combination, a crossover scheme which would play beautifully into the Paradigm's amazing response below normal crossover frequencies. Realizing few would bother to seek out such a perfect splice, we found the 60 Hz setting in the THX controller provided the most "correct" results, at a slight cost of upper end LFE track information. In this configuration there seemed to be no limit to the Studio 20s headroom. Ridiculous output levels could not alter their neutral character.
Truly this is "a speaker for all seasons".
perryg114
Thanks for the response folks I will do some research on the speakers that have been mentioned. It is hard to know where to start with these things. A sub woofer is in my future. I figure a good pair of mains is a start.
Perry
F
flyv65
I think the most important thing you can do is take several CDs you're familiar with (ranging across the entire spectrum of the music you listen to) to your local dealers and listen to ALOT of different speakers! You've got a lot of choices out there: quite a few people use a pair of monitors for their mains with a matched sub and are extremely happy. Others won't tolerate less than three (or four, or five)-way floorstanders with 8" drivers. My caveat to you is that whatever you choose for your electronics (Pre-Pro, DVD, etc.) will (probably) be out-dated in one to two years, but a quality set of speakers will last you decades: spend your money where you see fit.
Bryan...and yes, I love my Spendors (but they weren't cheap)...
N
newfmp3
My vote is for the Axiom M60's with that amp. Nothing in the paradigm lineup impressed considering their cost. They are good yes, but worth more then the Axiom's? I don't think so. It really comes down to your own ears though. You can even go through the factory outlet on Axiom and get another %10 off. I never suggest bookshelves if you are planning to use floor stands. No bookshelf is going to have decent bass on it's on, and when you factor in the cost of the overly priced stands, and they are all over priced, you are better off with the floor standers to begin with sometimes.
Axiom is a free 30 day in home trial. Costs shipping back and that's it. I have my doubts you will send them back. But don't listen to the M80's if you can't afford them. Don't even look at them in person, because you WILL want them and then you'll need a bigger amp too. :)
Good luck
Doug Plumb
Doug Plumb
loudspeakers - which is best
I'm partial to:
PSB, Paradigm, Energy, Mirage for under 1K - or well over 1 K for that matter.
