WHICH SUBWOOFER SHOULD I GET? PLEASE HELP ( I have the Klipsch rf-7 for my mains)
panos88
Hello all ..... Well if you had to choose between the Velodyne DD15 or the Velodyne DLS5000R which would you get? I am looking to buy 2 of whichever is best for my system.
My main speakers are the Klipsch RF-7 - I have one DD-15 but honestly the Klipsch drown it. Should I get the DLS5000R ?
Any help is appreciated.
Pete
mike c
mike c
i remember one guy on AVS also having Klipsch speakers return a DD18 because it couldn't keep up with this Klipsch's. if you ask Curt C of Velodyne, he would also recommend the Velodyne DLS-5000R as well.
but if we are talking about this much budget, I would recommend DUAL SVS PB13 Ultras instead, for the price of ONE DD15
panos88
What is the difference between a class A or a cladd D amp in a subwoofer?
Thanks for your help eveyone ... this is a GREAT website !!!
I am asking because I am considering the DLS5000R sub over my DD-15 sub.
mike c
mike c
i agree croseiv
in terms of sound quality, there is no difference.
in terms of weight, efficiency, power consumption, size ... the class D amp is smaller, lighter, more efficient therefore eats up less electricity.
btw, I have merged your two threads.
Warpdrv
Warpdrv
What are you looking to gain here...
Power to match the extremely efficient Klipsch......?
What is the size of your room...?
Mike's suggestion of getting a pair of Ultra 13's isn't bad, they might trump dual DD-15's in tuning flexiblilty, SPL, linearity, and possibly SQ.
On the other hand, with the DD series, you have a built in EQ, which adds to the ability to smooth out room responses. I find that to be a priceless piece of equipment. You could also get an outboard SMS-1 to do the same thing.
If you were to sell the DD-15, you could possibly buy dual SVS Ultra 13's and a SMS-1 for close to the same price of adding a second DD-15...
Hard decision...
mike c
mike c
well, not really a hard decision ... i would actually say it was a very easy decision.
use the money for a new DD15 and sell the old one to buy an SMS-1 and quad PB13 Ultras :)
but like i said, even the DD18 (which has at least 30% more output than the DD15 IIRC) couldn't keep up with the Klipsch mains for this other guy :)
Sheep
Sheep
The SMS-1 can only EQ 3 subs. Fail.
SheepStar
mike c
mike c
SheepStar
option 1: balanced output to the balanced input on the PB13 Ultra. FTW!
option 2: y splitter. FTW!
:D
mike c
mike c
as long as you're cutting peaks, i don't see why not ...
it works with mine.
panos88
my room is 18 x 26 feet. The ceiling is 9 ft 4 inches. Its about 5000 sq ft in volume.
I spoke to curt and he sis recommend the velodyn dls5000r sub ( a pair of them). When I look at the price ... it seems to good to be true! Am I wrong here? I can actually buy 2 of these for 1200 bucks.
I will say I am dissapointed with my DD-15 (not to mention I am sending the amp out to get repaired after attempting to troubleshoot it with curt. I have had this sub for 7 months ... NEVER crancked i up because I was too busy building my theater. I bought it new from a secondary vendor for 2100.00
mad? you bet I am .... for the reputation that velodyne has .... this is a nightmare!!! I miss my M&K - I wish i never sold it!
panos88
warrp....
I want to watcha movie and feel my chest shake apart .... thats what I want!!!!
to this day ... I have NEVER got that effect
mike c
mike c
i have a DD18 and DUAL DLS-5000R's. and i am recommending/guaranteeing that the SVS PB13 Ultra will trounce ANY and ALL velodyne subwoofers - even those three together.
do yourself a favor:
www.svsound.com
i don't like sounding like a fanboy, but it's that good. two third party tests have proven so as well.
panos88
mike .....
1 or 2 of these units? what are you recommending ?
mike c
mike c
2 will cost the same as one brand new DD15 or DD18 (depending on your discount)
or you can start with ONE PB13 Ultra + SMS-1
Warpdrv
Warpdrv
2 of the SVS's Ultra 13's would have scary output in that size room...
I have dual Plus/2's in a room 8200 cu ft, and the output is incredible, when they are tuned at 20hz, they provide waves of bass that are unimaginable by most people...
The Ultras offer a little cleaner bass then the Plus/2's....
