Which sub to go with Klipsch RF-52
strawks
strawks
Hi all,
After listening to a few loudspeakers I have purchased a pair of Klipsch RF-52. They will be driven by a Denon AVR-2308 (I don't really know if it is a good choice as I'm no expert in this domain, just followed some advice from the vendor).
Now I'm thinking of buying a subwoofer to have a 2.1 HT system (I don't listen to music so often). Maybe I will upgrade it to a 5.1 system later.
I first thought of a klipsch RW-10d but it seems it's not a really good choice?
I read that Klipsch loudspeakers are often used with SVS subs.
Which sub would you suggest me (<=500€ if possible)? The room is ~40m² (7m x 5.5m).
regards,
strawks
rnatalli
SVS and HSU are my two favorites. With Klipsch, I'd probably lean HSU as they are a hair more articulate and musical. Can't go wrong either way really.
AVRat
AVRat
Most Klipsch subs are underwhelming. I believe you should be able to purchase an SVS PB10-NSD in Europe that performs very well.
strawks
strawks
Since HSU seems to be harder to find in Europe and maybe a bit more expensive, I'll go for a SVS PB10-NSD, thanks for your answers.
