Which SUB to choose?
coolioo
Hello guys,
I wish to buy a sub and can't decide because I have limited options (because of retailers and money - I leave in Romania). Please don't recommend other subs than those listed below because I will not be able to purchage them. The sub will be mostly used for movies and rarely for music (I usually listen hard-rock and pop-rock so there is not so much bass requirement). My room is quite small, about 25m2
My options are:
GROUP1:
-System Fidelity 250SW
-Infinity Primus PS8
-PSB Subseries 1
-Pioneer S-W160S-K
-Wharfedale Diamond SW150
-Wharfedale Vardus VR-Sub10
-Dali AW 8
-Klipsch KSW-10
-Infinity Beta SW 10
-System Fidelity SF-250SW
GROUP2 (more expensive with 50-100 euros than group1)
-Monitor Audio BRW10
-Kef C4
-Celestion S80
-Infinity PSW8
-Boston Acoustics PS8WI
GROUP3 (more expensive with 150 euros than group1)
-System Fidelity SF-300SW
-Mordaunt-Short Avant 309i
Midcow2
Midcow2
Can you get SVS or Hsu where you are ?
Hello guys,
My options are:
GROUP1:
-PSB Subseries 1
-Pioneer S-W160S-K
-Dali AW 8
-Klipsch KSW-10
-Kef C4
-Celestion S80
-Infinity PSW8
Can you get SVS or Hsu ?
SVS PB10-NSD $429 USA
http://www.svsound.com/products-sub-box-10nsd.cfm
Hsu STF-1 $299 USA
http://www.hsuresearch.com/products/stf-1.html
Good Luck!
MidCow2
coolioo
No I can't get SVS and HSU. They are very expensive in Europe, and there are no retailers in Romania.
Midcow2
Midcow2
Sorry don't know a whole lot about the other subs on your list. I had a similar Klipsch 10" sub that sounded pretty good.
Good luck!
MidCow2
picture_shooter
picture_shooter
if your on a budget, just go w/ one of the ones on group. When I started, I started off small (budget) and worked up to what I have (had) :D and it was very fun.
Can you demo Canton or KEF out in your neck of the woods?
leo1058
leo1058
klipsch is the only one i've heard of from your list. it sounded well in the small demo room i went to.
coolioo
Thanks for your input guys... I hope that I can get more opinions from other people.
Chopin_Guy
Chopin_Guy
I know the infinity beta sw-10 you have listed is supposed to be a competent sub, with a fairly beefy amplifier...I also believe it has that Infinity RABOS system, which is essentially parametric EQ which will help tune the sub in your room...
coolioo
You could recommend other subs from hxxp://www.artson.ro/home-cinema-subwoofer/ and hxxp://www.sono.ro/subwoofere-127_130.html but shouldn't be more expensive than 1400 Lei(RON) (I hope that I didn't broke any rules by posting this link here).
E
Exit
In general, the bass requirement for movies is actually more demanding in very low frequency reproduction (i.e. less than 30 Hz) than music. This is the range where a lot of movie special effects occur. If you are in an appartment or condo, you may not want a subwoofer that goes much below 30 Hz because of potential complaints from neighbors that the sound is traveling through the walls to loud (actually too deep). If so you can get by with a relatively less expensive subwoofer, because you pay more of a premium for less than 30 Hz bass.
I would try and find reviews of your subwoofer candidates and see if you can eliminate some based on published performance and critical listener reviews. Then maybe you could go and listen to a few that are still candidates. It is hard to compare subwoofers in a store because so many factors with room interaction are involved. If you do find a subwoofer that sounds good in a store, at least you know under that room's particular acoustics the subwoofer has the potential to sound good. Parametric equalizers (i.e. RABOS, BFD, Audyssey in receivers, etc.) can be used to partially compensate for room frequency response problems. Audyssey (in receivers generally) also does correction in the time domain which provides a very clear and directional soundstage in typical house rooms. There are also room acoustic treatments which can be used to get rid of room acoustic problems. You can read about them in the room acoustics forum.
coolioo
Well I just browsed the web for some reviews and I have found good reviews for Klipsch KSW-10 and Infinity Beta SW-12. I didn't found any review for Infinity Beta SW-10 which is the smaller and cheaper brother of SW-12 so I'm wondering if anyone has/had this sub.
So i'm considering either a Klipsch KSW-10 or Infinity Beta SW-10. What do you think?
