Ok so I bought 2 flat packs from diysoundgroup a few days ago and am planning on separating out my dual 10" Eclipse subs. Right now they are both in very small 0.6 cubic ft sealed boxes that is a dual single enclosure. I am planning on putting them into sealed 1.25 cubic foot boxes. They are dual 4 ohm VC so I will run each at 2 ohms. So basically that means my Adcom that I am using now is out since it can not handle the 2 ohm load and I am looking to go with a pro amp. Based on my research I am between the Crown XLS1000 or the Behringer INuke 1000 DSP.
From my limited understaning, I thin the INuke gives me better functionality to control the boost level and has better subsonic filter, while the Crown is a better and more reliable amp section. Am I right with that statement??
Both have similar output ratings.....which would you guys go with?? I think both will basically give me the same ability to increase boost below 40hz and help my sealed units stretch down into the mid to upper 20hz ranges.
What would you go with.....I am open to other ideas also.
Thanks
Jeff
