philh
Parts Express 250W Plate Amp $128
This high performance amplifier has all the power and advanced features that you've been looking for! The adjustable phase control provides flexibility in subwoofer room placement allowing you to "shift" the phase and fine tune the subwoofer's output to their particular room environment. Until now, this feature was only found on high-end subwoofer systems costing thousands of dollars!
Specifications: • Measured power output: 180 watts RMS into 8 ohms @ .1% THD, 272 watts into 4 ohms @ 0.2% THD • Signal to noise ratio: 101dB (A-weighted) • Dimensions: 10-3/8" W x 10-7/16" H x 3-1/4" D • Enclosure cut out: 9" W x 9-1/4" H • Voltage: Selectable, 115/230V, 50-60 Hz, 450W
High-Power Class AB Amplifier
Variable Phase Adjustment
Rumble Filter
High-Pass Filter for Satellite Speakers
Auto On/Off Circuit
Gold plated connectors
Madisound Keiga 300W Plate Amp $225
.Discrete high current drivers and output devices.
.Low pass frequency adjustable.
.Woofer level control.
.Phase invert switch control.
.Auto on/off control.
.Provide high level and low level in/out.
.Binding post high level in/out terminal.
.Output protection circuit with relay.
.IEC power socket.
.LED power indicator.
.Master power switch.
.AC 115V/230V switchable.
SPECIFICATIONS
Power output @ 4 Ohms 300W
T.H.D. 0.08%
S/N ratio @ rated power 85dB
Input sensitivity @ low level 75 mv/100Hz
@ high level 3.5 v/100Hz
Input impedance 22 kW
Variable low pass freq. 50~100 Hz
Dimension WxHxD 250x250x115 mm
Rumble Filter
Auto On/Off Circuit
.IEC power socket.
SPECIFICATIONS
T.H.D. 0.08%
