Hi,
Do any of you have success playing back dual layer dvd's on your stand alone player? I'm using Ridata 2.4x and tried it on my sony dvp-nc80v. It always locks up on the menu's, chapter selection. if a movie does play, fast forward shows extremely pixelated image.
Is there any easy way to find out if a unit will playback dual before buying? I'm looking for a low cost unit under $150.00
I like the LiteOn DVD recorder, I guess I would run into the same problem if I record tv shows with dual layer discs so there has to be some units out there that can handle dual layer playback without any issues?!?!?
Thanks!
