AVR1610 for powering Monitor 70 and other polk audio speakers?
Hi,
I have a very similar question. I have bought PolkAudio CS2, Monitor 70s, Monitor 40s and PSW505 for Sub. My TV is Panasonic Plasma 50". I do not listen at high volumes. I listen to music & watch movies (blu ray). No PS3 or XBox involved.
I do not need to upscale, but upconverting is needed (component and composite to HDMI)
Question is:
Can the 1610 drive these speakers with sufficient head room? Some of the speakers are rated high, for instance: Monitor 70's recommended amplifier specification is 20-275 w/ channel, Monitor 40 is 20-125 w /channel.
If I dont have the need to play at large volumes (say definitely not at reference levels, from reading through the forums, it looks like reference level is high volume), will I be sacrificing sound quality if I compare it to say AVR 1910 or AVR 2310? I am sure the 2310 might have some better sound, being the higher model, what I am asking is, if the sound quality will be substantially better in the 2310, for instance going from 70% to 95% as opposed to 90% to 95%? I have never used more than TV speakers in the past, so I am not an expert here.
Please help.
Edit: Also, please let me know if the Onkyo HT-RC160 is a good choice and will work with respect to powering the speakers up? If yes for both Onkyo and Denon, which would I go with?
