Which Receiver should I get with my new system? Deftech RLS in walls
branchman5000
Hey everyone,
I just purchased a new home yesterday and it will be built over the next 5-6 months. I am going to put in an in-wall system Definitive Technology 3 RLS II or III (STILL DECIDING INPUT NEEDED) for the mains and center. 2 UIW RSS II and 2 UIW RCS II and a SVS or HSU 12'' sub. I need help with a great receiver to power these. I also need a 2nd zone for a pair of outdoor speakers. Any recommendations?
Thanks guys.
branchman5000
I was thinking if I could get a good deal, using Marantz - AV8801 Processor / MM8077 Seven Channel Amplifier for this setup. Would this be overkill?
BMXTRIX
BMXTRIX
The 8801 is not really a good deal. Their amp really isn't either. Not that they are bad, but they are pricey for what you get IMO. I would ask that you be very aware that any in-wall speakers will bleed noise over to adjacent rooms significantly. For ceiling speakers, this is also the case for any rooms which are directly overhead. I like using in-walls and in-ceiling speakers, but I've taken care, mostly through bad experiences, in ensuring that adjacent areas won't be disturbed by my use of in-wall/ceiling speakers. That said, if you want to go with some solid power behind those speakers to really get a lot out of them, then why not consider something like the RX-880 from Yamaha, then pair it with something like the XPA-5 from Emotiva, or even go with the MM8077 from Marantz. Depending on what speakers you want outside, you may want an external amp for those speakers as well, which means you could double up with two XPA-5 amps from Emotiva to deliver a lot of power outdoors, as well as having 200WPC across all the indoor speakers. The A/V receiver/preamp doesn't need to do much more than deliver clean sound to the preouts which Yamaha can do nicely in a lower cost product which should make you happy. Finally, consider what sources you want for outside. You will have a very limited number of analog audio inputs regardless of most manufacturers, and you must feed analog audio for zone 2 sources. So, if you want 7 sources available outside, you may need a different, or an additional, product to get it.
branchman5000
How did you ensure that the adjacent areas were not affected? The only areas that are connected are my master batch (upstairs), bonus room (upstairs) and a formal dining room.
I've never been a huge fan of Yamaha, no offense, I've just never really found anyone that really enjoyed the product. Are there any others that you suggest I look into?
branchman5000
My budget is flexible. I'm not trying to skimp on performance but I am also keeping in mind that these are not B&W 802D's that I will be using either. I should say I am willing to spend the money to have a processor/amp or receiver that will last me many years to come.
The reason I chose to go with the DefTech RLS in wall system is to save space and use it mostly for TV/SPORTS/MOVIES. It is not a dedicated theater but I want something nice enough to make me feel like I'm still at the Seahawks games when I'm watching them on their away games.
branchman5000
I like the denon. Has anyone used the marantz sr6007 or sr7007? Would that be worth the extra money?
I don't think so, the 3313 fits in between the 6007 and 7007 in terms of specs but the 7007 seem way overpriced for some reasons. Marantz does not sound better than equivalent Denon, people started something years ago, and it goes from hearsay to myths, that some people think as a brand they sound better than others. I would just go with the feature set you need and then go with the one that you can get the better deal for.
GlocksRock
GlocksRock
I have a couple Denon recievers and love them very much. The Marantz offerings are nice, but I find them to be overpriced for what you get. Stick with Yamaha or Denon and you will be happy. The speakers you have don't need a ton of power, so any decent reciever will have no problem driving them.
branchman5000
Thank you everyone for you input. I really appreciate it. I am going to go with the Denon.
