which receiver is better?
G
gaminguru
im caught in the middle btw the denon 3808 n onkyo 707 receivers...which has better sound quality? im using a set of jbl speakers.
markw
It's a toss-up. The speakers and the room determine 99.9% o the overall sound. Be more concerned about which one has the eatures you need.
But, or my uses, I personally tend to prefer Denons.
I would pick the Denon 3808 100% of the time, but that's just me.:D
GlocksRock
GlocksRock
I too would go for the Denon over the Onkyo.
sholling
sholling
They are going to sound the same so pick the one with the features that you want. I happen to run Onkyos because they are great bang for the buck, but as I said pick the one that has the features that you like.
GlocksRock
GlocksRock
You animal!!!:D
I guess they just don't call us Audioholics for nothing.:eek:
Yeah, I am an addict. I will say the Denons are more difficult to setup than my Yamahas, but not too bad. I got the 1910 for a 3rd little system I have, but that system probably won't get too much use... but for the little bit of time I spent messing with it last night I was impressed.
