5.0mm or 8.0mm I am going to plug it into the Onkyo 605. Thanks.
S shockemags Junior Audioholic Jul 28, 2007 #1 5.0mm or 8.0mm I am going to plug it into the Onkyo 605. Thanks.
BMXTRIX Audioholic Warlord Jul 29, 2007 #2 Either will work. I have a bunch of their 'premium' cables and they feel and look really nice. For a couple of bucks more, you can spend it if you want and enjoy the nicer build quality. Or save a couple of bucks (literally) and use the very cheap one. Both will deliver identical results.
OttoMatic Senior Audioholic Jul 29, 2007 #3 BMXTRIX is right. I bought the latter just because I liked the better build quality, and it was like $2 more. If it was $20 more, I would have purchased the former. If it's not defective you won't hear any difference in sound.
mtrycrafts Seriously, I have no life. Jul 29, 2007 #4 BMXTRIX said: Either will work. I have a bunch of their 'premium' cables and they feel and look really nice. For a couple of bucks more, you can spend it if you want and enjoy the nicer build quality. Or save a couple of bucks (literally) and use the very cheap one. Both will deliver identical results. Click to expand... I wonder how they can sell it for $3.94 and still make a profit. Anything more expensive must be a real rip off.
Hi Ho Audioholic Samurai Jul 29, 2007 #5 I have a word of warning about the optical connector on the 360. It is designed in such a way that "premium" cables with more bulky connectors such as the Monoprice premium models may not fit tight and will fall out very easily. You may in fact be better off with the standard cable.
