silas
<font color='#000000'>I have a Denon 2802 what would be a good amp to mate with her. I have looked at B&amp;K 125.5, Rotel RMB1075 Etc. Speakers are Mirage OM-7 front Om-C3 Center, OM-R2 rears Sub Klipsch KSW-12 room size is about 20x24
</font>
Yamahaluver
Yamahaluver
<font color='#0000FF'>The Denon POA series power amps are pretty well built and also integrates well with your Denon receiver. You can also look at Marantz PA series amps as well as Yamaha MX series amps.</font>
G
Guest
Guest
<font color='#000000'>Check out the reviews on the Anthem site, one of them hooked the amp to a Denon 58?? with success. &nbsp;Rotel and Anthem seem to offer the best value...if you believe the reviews.</font>
silas
<font color='#000000'>update friend let me borrow one of his B&amp;K A150 2x150 channel amp this is an extra he runs 4 of these now (life is rough) I am using it to power the fronts just gotta put the S&amp;V setup disc in but it seems to really open up the fronts.
</font>
