Which Martin Logan's Should I Get?
scr0da
I recently purchased (2) Martin Logan Electromotion ESLs.
I do not have a center and do not have a subwoofer yet.
Any suggestions would be appreciated....
or any current deals you may know about would be appreciated....
Adam
Adam
No suggestions...just a comment. I'm jealous. :D
If you don't mind me polluting your thread - how do you like them?
EDIT: I'm sure that you've seen ML recommendation of the EM-C2 center channel for those.
scr0da
No i haven't seen the EM-C2 center channel.
I don't even see it on their website. Where do you find such suggestions?
scr0da
So far so good on them. It's an entirely different sound than other "older" speakers I am used to listening to.
As you know, I'm having trouble using them in certain "scenarios" but, it's not the speakers fault :)
Adam
Adam
I just looked up your speakers on the ML website, and it had those listed on the same page. So, I looked them up. ML doesn't have a product page for them, yet, but they do have a press release. The C2 is also shown in the user's manual for your speakers (page 15, figure 13), so I just assumed that it was their recommendation.
scr0da
An $800.00 Center? Isn't that excessive? :)
It's not even available on ebay......yet.
G
GinMaster
ML Advice
About 4 weeks ago, I called ML and asked their recommendation for a ML center channel speaker to match the new ElectroMotion electrostatics I was buying. At that time, the sales rep suggested using an electrostatic center channel for superior voice matching. The ML electrostat center channels (Matinee, Feature, Motif, and Stage) range in price from $1,500 - $3,000 and were outside my budget. But since I noticed that the ESL C2 center channels were not yet shipping, I took the "voice pairing" issue with a grain of salt.
Last week I ordered from OneCall the ESL C2 for $800--expensive, but about half the cost of ML's electrostatic center channels. The C2 shipped immediately and arrived yesterday. I've not yet installed it, but look forward to hearing the dialogue in HT use. Since center channel is not encoded in normal stereo audio recordings, I don't think the "voice matching" is likely to ruin my day.
By the way, I also accepted in part and rejected in part ML's advice regarding a subwoofer. That same sales rep advised against the ML Dynamo ($500) because its ported design results in less precise audio reproduction (fine for HT, but not so good for music). ML advised using the closed cabinet Dynamo 700 ($700), which again was above my budget. My research confirmed the advantages of closed cabinet subs, so I purchased a closed cabinet Emotiva Sub 12 ($429) which does sound better than the ML Dynamo 500 (I could not find demo for the ML Dynamo 700).
Of course, I make lots of mistakes and probably worry too much about saving a few dollars for retirement. ;)
GinMaster
Adam
Adam
Thanks for the information, GinMaster, and welcome to the forum!
I hope that you'll post again after you've tried out the C2. I'd like to know how you like it.
Hocky
The C2 center should be voiced close enough since it is in the same product line. It is tough, though - I tried a few different center channels trying to avoid buying an ESL center and ultimately none of them were good enough. But those center channels weren't in the same product line as my speakers, either. ;-)
