which is better pick between b&w mt50 & mt60 and paradigm millineaone with sub
suniltgeorge
Hey the head says it all .
Also Brandname wise which is better
Which will be the best in a small hometheater room setup
suniltgeorge
I'm sticking with these speaker choices cus it's a small room :) but I want to choose the best out of them .. can u suggest if u can tell me why :) thank yu
I am not sure what small room has to do with the advice that was given:confused:
The "best" means you need to go listen to them for yourself and decide which of those two you like the best.
N
NewHTbuyer
I haven't heard them, but the Paradigm has gotten some good professional and user reviews. My advice with either set is to just get the speakers and skip the sub. Then get a much better sub from a company like SVS, Hsu, PSA, or Rythmik.
