which HOME THEATRE is better ?
conada
hey there guyz, i'm buying a home theatre for my room to play with my ps3 and samsung 750 hdmi TV. I don't need expensive home theatre, so here are the 3 that i'm looking to buy. please give me an advice so i can pick one up soon. thanks
1)Samsung HT-TX72T 1200 Watt Home theater Surround Sound System - 5 Disc HDMI USB -------i can get this for $199.99
2)Panasonic SC-HT40 ------i can get this for $169.99
3)Samsung HT-AS720 ------i can get this for $199.99
Thank you guyz !!
Davemcc
Davemcc
Which one has an HDMI input so you can use that PS3 properly?
lsiberian
lsiberian
Go with the Panasonic. They make good low-end stereos.
bsblfan
save your money for a good receiver
I purchased the sammy 750 46 and I use a Ps3 for blueray. I just had the TV
calibrated which made the picture go from great to spectacular. What really set this system off was the Yamaha 3900 I am using with it The difference in sound is major and also upscales the picture to 1080p. figure it out. bsb
