Which AV123 speakers should I buy?
Status
Not open for further replies.
O
Onixbull
I couldn't leave well enough alone and had to get myself permanently banned by coming up with this clever alt.
jcPanny
jcPanny
AV123 speakers
If you listen to a majority of HT, I don't think you can go wrong with the Rocket line. Check out this speacial they are running on a 5.0 Rocket speaker system for $2k:
http://av123forum.com/showthread.php?t=32643
Add 1 or 2 of the MFW-15 subs and you will be set. Don't expect the Rockets to be in stock, but they will be worth the wait.
I have the Ref 1's, Ref 100 and ELT525s in my HT. If you listen to a lot of 2 channel music, you might consider The Strata Mini's (used or b-stock), Ref 100s and Ref 1's or ELT's for surround.
O
Onixbull
The Rockets are out of stock? That's a bummer. I need something soon.
How are the Ref speakers?
Status
