Don't run any low voltage wiring close to, or parallel to high voltage wiring. If you absolutely must intersect with high voltage wiring, cross at a right angle, in order to avoid noise pickup. Use the shortest route possible, avoid lights, kinking the wire and pulling it too tightly. If you don't want to buy all kinds of wire mounting clips, etc, hammer Romex staples with the nails in line with the wire's direction and use wire ties to secure the cables to the staples. Place them at the center of the studs and joists. If you need to drill through joists, drill in the middle 1/3 of it's height and never drill through Micro-Lam. Engineered I joists can be drilled or you can route the wire through the knock-outs. If you drill through 2x4 studs for horizontal runs, drill in the center of the stud and put nailing plates over the wire. Nailing plates are in the electrical aisle at Home Depot, etc.
