Where to find a replacement Spindle/Take-Up Reel/Pin to repair my Denon DRR-M30?
  • Thread starter Thread starter iKokomo
I
iKokomo
Jun 3, 2016
30
0
6
48
Long story short, one of the Spindle/Take-Up Reel/Pins (I am not sure of the technical term, please see pictures) has cracked and only intermittently turns the cassette. So sometimes it works, sometimes it doesn't.
My unit is a Denon DRR-M30.
I would like to replace this one piece, however, I am not sure what part I need to look for.
Can anyone help me find this part so I can fully restore this cassette deck?
Thanks!
isidore newman
Thanks!
isidore newman
If you are referring to the cap part of the assembly...
I would pull it off...pump a couple of drops of super glue inside it, holding it upside down and on its side while rotating it to let the glue coat the entire interior evenly.
I would bet that that would work.
If it didn't work, that's just a standard spindle (I think)....look for any cassette deck at a flea market.etc. and use a spindle from that.
That is a really bad idea.
I can't find a service manual I don't have to pay for. But there are a number of sites you can download a service manual from for a fee. That is your first step. That will tell you how to proceed.
You probably need a part, and there are firms that service cassette decks, but they usually restrict themselves to certain manufacturers and models. That is usually because they have hoarded parts from certain decks.
Denon decks are on the list that BC Electronics service, but like many they will not touch auto reverse cassette decks. That is because they are miserable to work on.
You will probably find that replacing that spindle is not a simple operation.
Tape recorder repairs are seldom simple. I know because I have done quite a lot of them.
Yeah...it's a desperate idea for sure, since doing an actual replacement/repair is going to involve finding parts and some surgical level workmanship. It's actually discussed here....
Thanks!
isidore newman
here is the updates check it out
It's unfortunate to hear about the issue with your cassette deck, but I can certainly help point you in the right direction for finding the replacement part you need. Based on the description you provided and the pictures you shared, it sounds like you may need to replace the spindle, take-up reel, or pinch roller, which are all critical components of the cassette mechanism. These parts are responsible for controlling the movement of the cassette tape, and any damage or wear to these parts can cause issues with playback or recording. To find the correct replacement part for your Denon DRR-M30 cassette deck, you may want to start by contacting the manufacturer directly or a certified repair center. They may be able to help you identify the specific part you need and provide guidance on how to replace it. Alternatively, you could try searching for replacement parts online through websites such as eBay, Amazon, or specialty audio parts retailers. Be sure to search for parts that are compatible with your specific model of cassette deck and that match the specifications and dimensions of the original parts. Before attempting to replace any parts yourself, make sure you have the proper tools and knowledge to do so safely and effectively. If you are unsure or uncomfortable with the process, it may be best to seek the assistance of a professional audio technician or repair specialist.
Getting hold of Denon will be a complete waste of time, and so will contacting a Denon repair center. These tape decks are vintage and Denon will have no interest, and be of zero help.
His first step is to purchase a service manual, which also has the parts list. This is available for little money from a number of sources as download.
Once he has a service manual he will know what part, or parts he needs, and if he feels competent to do the repair. If not he will have to find a specialist restorer.
Take the one that is good as a pattern, and have someone 3D print another?
They don't support old technology but if you can find another similar machine, you could remove the transport and replace it as an assembly, rather than searching for one little part that's effectively a Unicorn.
A donor machine may be the best option. Those take-up reels are usually held in place with a plastic c-clip at the top. The question is whether the broken reel will lift off of the shaft, or whether there is more of the reel underneath the metal plate. If that reel has to drop down through the hole instead of just lifting off of the shaft, then it's one big PITA to replace. If it slides up off of the shaft, a 3-printed one is possible or search E-bay for a donor machine. There are some listed on hifishark.com but shipping charges could be cost prohibitive.
