where to buy subwoofer enclosers?
ticks77
im looking to buy a nice subwoofer encloser for my dayton HF 15" (great sounding woofer by the way) i currently have teh HF 12 in the dayton boxes they sell at P and E but its ugly sounds good but ugly!!
is there anywhere eles i can buy just the box a pretty shinny box maybe a black mirror finish!!? that sounds just as good or better
the HF 12 will be for sell soon not even 3 months old i just found a awesome deal on a 15 and i liked the 12 sooo much i said why not.
If you want it, you will have to build it. Every woofer needs a different sized enclosure and port. Aligning the set up correctly is crucial, or it will suck big time. There are lots of threads on this forum about building your own subs.
annunaki
annunaki
Moderator
A proper glossy finish takes time to achieve. It requires lots of sanding and filling to make sure the surface is absolutely smooth, painting, sanding, painting again, sanding again, painting again, wet sanding, clearcoating, wet sanding, clear coating again, and then a final polish. Pretty enclosures take time, cost money and are not cheap. Bulding yourself would be the most economical.
Parts for the actual enclosure usually run about $40-$50 if you have all of the tools necessary.
Materials for finishing an enclosure (to a proper glossy/mirror finish) will be at least that & probably more depending upon the type of paint used. The time is the biggest part. High quality finishes cannot be rushed. They need to be applied properly too with a good sprayer & wet sander.
ticks77
thanks for the post i dont have the time or the skill to build it guess ill get a PandE box as i already know it sounds great maybe i can find some plastic molding or something to put around it to give me the look i want anyone know of any?
Plastic! I thought you were looking for something classy.
ticks77
lol you know like the plastic panio black on my samsung lcd tv its pretty i seen a sub with it on it and it looked awesome
If you think the plastic trim on a Samsung TV is pretty, then I think you need to further your fine arts education. Heaven help our civilization.
