I hate to buy speakers online, because i can't hear it before i buy it. yeah, maybe theres specs i can look at, but when buying speakers, specs on paper doesn't really tell you much. Especially when it doesn't tell me the most important (to me) factor, THD. Because theses speakers are for home audio, and not car audio, sound quality plays a really important role.
As I thought you have no clue. The T/S parameters tell you everything, as long as the manufacturer has measured and stated them honestly and his product is consistent unit to unit to unit.
In particular, the European manufacturer's T/S parameters and acoustic responses are brutally honest.
Between the T/S parameters and the acoustic response the driver is precisely defined.
If you don't know what these are and how to use them you can NOT build a speaker.
I really doubt you could get anything worthwhile no matter how good the driver was you bought. You have yet to convince me you know how to use the specification to design a speaker that is any good.
The distortion is only really relevant in the measurement of the total design.
The loading and total finished design and build will determine that. The driver is only one component determining that.
And one other thing, pray tell me how you audition a raw driver!
Your posts so far have enough red flags to line an esplanade.
