Where should I put the speakers???
Sd4Life
Hey guys, I just found your guys website and it looks pretty cool and informative. I got a surround sound system a few weeks ago and I'm having trouble figuring out where to put the speakers. Below is the layout for my front room. I can't really move things around much because of where the sat. and phone lines are at. Can you guys give me any suggestions as to where I should put the speakers and subwoffer? I really appreciate it!!! Thanks a lot!!!
jbracing24
With the present set up, I would try the side surrounds, one near the top right corner and the other opposite, on the bottom wall near the chair. The sub should go on the wall on either side of the entertainment centre, but you may want to do the silly but often works method of putting the sub in your prime listening area and lay on your back in one of the proposed areas just to see what effects you can get. Just don't let the neighbours see you!!!
