Where should i put my subsonic filter at?
I
Inertia
I just had a simple kappa perfect enclosure built.... where do i put my subsonic filter at for this sub and enclosure?
MidnightSensi
MidnightSensi
None. If your having bottoming out problems or want more audible output, you might try putting one on to 18Hz.
Most applications I've seen subharmonic filters used are in prosound, where its variable and moves the low cut up as needed (meaning if there is lots of headroom no filter, but as the volume goes up to prevent distortion it raises the low cut to protect the woofers).
