Where Are the Best Room Locations to Place Subwoofers?
gene
gene
Audioholics Master Chief
Administrator
While we generally recommend the subwoofer crawl to help find the best spot to place a single subwoofer, there's no denying that a single subwoofer can't provide smooth response over a wide seating area. While multiple subwoofers can help deal with this issue, there aren't many guidelines floating around on how to make the most of them. Fortunately, Todd Welti of Harman has taken the time to share his research on the matter, including simulation results for a wide range of rooms, to help you find the best locations for your subs.
Optimum Room Locations for Subwoofers An Analysis
shadyJ
Speaker of the House
Staff member
VERY nice article, although I nearly went blind when I hit that wave equation. Still, this is top notch analysis. Although it may not get as many views respectively, articles like this are when Audioholics is at its best, in my opinion. Nice Work by Mr Welti.
gene
gene
Administrator
I am very appreciative of Todd Welti taking the time to do this article. I have many other topics I'd love for him and Harman to write on for us as I really appreciate and trust the research they do.
Sheep
Sheep
Thanks for doing this. I was running into some problems with my new theater setup regarding bass output at the listening position. Moving the sub to the back wall left inner (not dead center, but not the corner) from the front right corner increased a lot of my low end and allowed me to turn the subwoofer down. Once I build my new subwoofer they should have flat responses across the entire couch.
SheepStar
gene
gene
Administrator
Got this email feedback to Todd's Article:
Mr Todd Welti,
Greetings, I am a retired IATSE Live Theater Sound Engineer, after reading 'Optimum Room Locations for Subwoofers An Analysis' I had a few thoughts. Since I have designed many systems for specific emotional effects for live shows I noticed that you simulated several systems that I would never put in a theater unless I was trying to make the audience uncomfortable. Those being the setups with Subwoofers behind the audience. If I may offer a suggestion, I would run a simulation with three subwoofers along the front wall. One on center and the others on thirds. This Is my prefered setup for fidelity in musical productions. Although I do use more than three individule LF drivers the math should work out roughly the same. Shifting the delay between the center and sides will allow for most modes to be compensated for.
You have to remember that what looks good on a computer simulation does not account for the way humans percieve sound. Sound from behind is localized by the brain and generally makes people nervous/uneasy. This "spooky" effect is generally called "Voice of God" and is used only for effects.
I suspect this is why Quadrophonic sound never caught on, it is disorenting.
Sincerely;
Jason
Todd's Response:
Hi Jason,
Thanks for your comments! I will grant you – and hopefully I made it clear in the intro of the article – that, yes this is theoretical. It’s just the particular facet of subwoofer optimization that I am addressing. It is still useful if you are trying to avoid seat to seat variation.
I don’t have any configuration with subwoofers only behind the audience. The configurations are symmetrical. But there are some seating configurations that have the seats moved towards the rear, putting subs near the back of some listeners. It is true that there might be some vague rear localization for those seated very near the subwoofers. In my experience, this is more noticeable when listening only to the subs. When listening to the full range system, with subs crossed at 80 Hz., and properly located mains and surround, this is not so noticeable. If you thought it was an issue, you could remove the seats near the rear subs, or look into a side to side sub configuration.
Your suggested configuration of 3 subs along the front wont cancel ANY front to back modes in a passive mode, and I’m not getting into active optimization in this article. That is a whole different ball of wax.
Hillbilly
Hillbilly
Todd's Response:
Hi Jason,
Thank you Todd for the response.
I am quite aware that this is a simulation/theoretical equation you are working on. To clarify, my concern with symmetrical mono distribution for LF energy below 80Hz (as is a common XO point for home theatre) is that there is no coherent primary wave-front presented to the listener. With drivers on four sides you get a turbulent sound field. While this looks good to a microphone array the effect it has on people is quite different.
My other concern is that models like this utilize a Pink Noise generated mode model. I don't know too many people who enjoy listening to pink noise and in normal program material the transient nature of sound and the absorptive nature of rooms/people/furniture does not generally present a long enough decay time for anything but primary modes to form, if that.
I'm concerned that this line of theoretical mathematical modelling is a bit of a spherical cow. The models look great for a situation that does not exist.
(That situation being, a room with only microphones listening to the program material)
Sincerely,
Jason
Hillbilly
Hillbilly
Gene DellaSala
I would like to propose a simple experiment.
Two set-ups, one with four sub-woofers on center points around a room, another with three sub-woofers along the front wall on center and thirds
For the 4 driver setup
phase align however you want.
For the three driver setup
If the AVR has mono-LFE, side drivers phase delayed ~15 degrees.
If the AVR has dual LFE outputs then set the center sub to out 1 and the sides to out 2, set the delay to the side drivers -1ms.
Listen to whatever you want :D
Todd Welti
Hi Jason, thanks again for your thoughts!
I have thought about these issues as well. My stated priority is to try to reduce what can be large variations in seat to seat response. For these, the steady state (pink noise as you call it) response corresponds well to what we hear, in my experience. And, this is the "500 pound gorilla" in the room, as opposed to more subtle phase coherency issues. I'm not convinced that such a "coherent" wavefront ever exists, especially if there are multiple seats where phase between different sources won't add up the same anyway. In my full paper, there is also another metric called Variance of Spatial Average, with all the same analysis done for it as was done for the MSV and MOLn metrics. The VSA metric is all about flatness of response as opposed to seat to seat variance. I omitted it from the Audioholics article, since it was more of an afterthought anyway (the seat to seat variance always comes first for me). Anyway, if one wanted to try to maxmize "phase coherency", perhaps one would want to include the VSA metric to try to get flatter overall responses. It would complicate matters though. Aside: I may have forgotten to include it in the Audioholics article, but I am assuming that someone serious about optimizing their subwoofers would also be using at least a couple of bands of parametric eq to clean up any out of control resonances, and tighten up the sound. Yes, I believe in deft use of minimum phase correction filters.
What do you mean by "turbulent sound field"?
As for using steady state transfer functions, yes it is true that for example, a narrow resonance that looks bad in the SS response is not that audible with normal music program. I think that in the statistical analysis used in my modelling, those types of narrow band issues do not have much influence. In any case if not a SS analysis, what do you propose instead? Anything more complicated may tend to have too many degrees of freedom to be useful.
All this aside, I really like your suggestion to do a test. In order to make it relevant to the conditions I am assuming, one would need to do multiple seats though, and include a couple of bands of parametric eq for either option. Also, your proposed settings for the frontal sub setup begs a question. Would your 15 degree phase adjustment create "phase coherency", since that phase delay results in different time delays at different frequencies? Anyway, back to your test. To get definitive results, one would need to get at least several "subjects", double blind listening, multiple different programs, and other methods to control biases (this is one of the things I have been doing at Harman for the last 15 years). I could suggest a simpler test. You set up the two sub configurations in a room. Measured each sub to each of, say, 6 seats. Send me the measurements (impulse responses please). And I will calculate the results from your configuration and for the 4 sub setup (use corners please for this one). For the 4 sub setup, I'll use Sound Field Management to calculate the delays. Then i will apply some basic parametric eq to mine (and yours if you want). Then we just look at the calculated impulse responses to see if there is a clear difference in coherence, as judged by the width of the impulse response. Note that this will not be a simulation, but will represent the simple summation of the individual impulse responses, with appropriate delays and global eq. This will be exactly what you would measure in the room, since it is a linear system. What do you think?
