I have a yamaha htr-5890 that is giving me trouble. I don't really know much about this stuff so I'm hoping somebody would be able to give me a hand. So my receiver keeps turning off automatically once it hits a certain sound level. For example, if i watch a movie too loud, it'll shut off. But if i turn it down it's fine. Is it over heating or something or have i blown a fuse...or the amp? I know that one night i got plastered and was blaring my music pretty good and that's when it first cut out. Do i need to pick up a new receiver?
thanks for your help.
Check all your speaker wiring carefully. Make sure there are no whiskers at the receiver end or speaker, causing a short to the case or adjacent wires.
Now if it now cuts out at a lower volume than it did before you got plastered, you have done damage.
There are two possibilities.
1). You have damaged an output stage and it is now drawing more current than it should and setting off protection.
2). You have damaged one or more speakers. The overload may have started a partial voice coil melt down, and you have some shorted voice coil turns, lowering the impedance of a speaker or speakers.
You need to check the latter or you will damage your next receiver.
You need an ohm meter. You need to check the voice coil DC resistances of all your drivers. You will have to remove them to do this.
The compare the DC resistance of all identical drivers. Any that give a lower reading than the highest one are damaged and need replacement.
