Simple answer.
You don't.
Just because you have that exrtra speaker doesn't necessarialy mean you HAVE to hook it up, particularly in light of the previous posters ominous and potentialy true warning for hooking them in parallel.
And, should you consider wiring in series, be aware that the volume in both of them will be lower than the other speakers and you may, or may not, be able to compensate by boosting it and thereby running the possibility of running out of power.
