What's better for Surrounds speaker!
CosmicOne
I have a system consists of:
Yamaha RXV-650
Sony DVD NS-305
Wharfedale Diamond8.4 fronts
Wharfedale Diamond8center
i want to buy surround speakers so i want to know what do u think,
it will be very difficult to attach the speakers to the wall,but what do u think gonna give me better results??
1-Get the Diamond8.3 (80cm tall) & place them on a 37Cm stand(which i already have) the cost will be=110UK pounds
2-Get the Diamond8.1(29cm tall) & place them on a stand (122cm tall) the cost=100UK pounds.
am choosing between those options coz i don't have the abaility to attach them to the wall & i heared from alot of people that the surrounds should be above ear level by a good hight to really experince surround?!!!
I only want Wharfedale Diamond8 speakers to complete the family of the speakers.
Unless you listen to lots of multi-channel music, the 8.1s should be fine. I'm wondering why you can't mount them higher up on a shelf?
CosmicOne
Hawke
with the design on my room i don't have the place & it's very very difficult to mount them on wall or shelf.
CosmicOne
I need the speakers that will give me the best performance as rear speakers in movies as i don't care much about multichannel music,while the difference in money between the 8.1 with stands or the 8.3 without buying standes is nothing,some people say get he 8.3 better & others say get the 8.1 coz floorstanders are bad as rears?????
am really confuesed now??
moverton
match the fronts if possible
I think the surround world is changing to expect the same speakers front and back. For DVD-A/SACD I see a lot of recomendations to this effect. I have small surrounds and just hooked up an SACD/DVD-A player. I now see why they recomend full size rear speakers. Some disks use the rears as if they were as important as the fronts. I think they are not treating them as just 'effect' speakers anymore. If you have the space I see no reason not to use full sized surrounds.
CosmicOne
Thanx Moverton,
u make my start to really lean towords the 8.3.
