What would you do? I need a lot of help...
deathfalcon
I am trying to be a guys audio engineer for his new house he is building; I'm stupid.
After many hours of research i have narrowed down what i think i am going to use.
Here's the deal:
there is to be a total of 40 speakers in 16 locations with 3 listening zones (i just want to clarify, because im not hip to the jargon, that by listening zone i mean separate input).
Two of the locations are outside and have 2 speakers each with specifications as follows: 60Hz-25kHz; 8ohm; 90dB; 10-100 watts per channel.
The remaining 36 speakers are inside and occupy the other 14 locations.
All of the inside speakers are: 40Hz-20kHZ; 8ohm; 89dB; 20-100 watts per channel.
AND THEN CAME AMPLIFIER TIME.....
The bane of my current existence.
Really, to simplify this, what would you do?
I've got to have enough channels and power to make this system work. also, the input thing... i need multiple inputs going to multiple configurable outputs.
Any feedback is appreciated, and i can give more info if needed.
