I think you correctly answered your own question.
Your receiver is the better bet. The 9555 uses a class D switching amp, similar to what is found in subs. However the unit does not appear to use a switching power supply and has a better conventional power supply.
The more expensive amp is probably around 45 watts per channel. Dynamic power is really bogus. The max power draw of that 9555 is only 110 watts. Now class D amps are efficient and approach 90%. But you can see it is not very powerful. I have been listening the "The Voice of Jupiter" (the RAH organ) from the Proms courtesy of the BBC this evening, and I think I would have run it out of gas pretty quickly on the deep sustained pedals.
Class D amps are known for a lot of problems.
Frequency response varying with the impedance curve of the speaker. Noise. Frequency response just about making it to 20 kHz and then falling rapidly. High frequency ringing. Not meeting their distortion specs with falling impedance.
Probably the best class D amps are made by Hypex, and sold on an OEM basis to a variety of manufacturers.
Here is their
100 watt module the UcD 100EM"]100 watt class D module the UcD100EM.[/URL]
Here are
John Atkinson's measurements of an amp that uses that module.
That module has been used extensively in Europe in active loudspeakers. In this application class D makes a lot of sense, and they perform much better when not having to contend with a passive crossover.
Your other issue is that the sonic signature of most speakers is so dominant, that the sonic effects of even relatively poor amps will be obscured by the sonic signature of speakers stomping over everything.
So if you are itchy for an upgrade put your money into speakers. That is always the best advice.
