What to look for in a Reciever?
marvontherim
I have an old Sony reciever that I am thinking og upgrading. I need help understanding what I should be looking for.
Watts, Channels etc etc
What makes one better than another?
How do you level or balance a system?
Thanks for your help
WmAx
WmAx
What to look for in an audio reciever:
1. Transistors
2. Circuit Board(s)
3. Wires
4. Power Supply
5. Various Other Stuff
-Chris
JMO_PWR
JMO_PWR
Well obviously your best to listen to differant brands of receivers within your price range (and out to distinguish wether its worth spending that little bit extra) and let your ear do the judgeing however.
I would always recommend Denon and Marantz. (Alot of experience with them just cant afford my own, yet)
However Things to Look at in a...
Receiver:
- Your video requirements (HDMI, Component etc.) Look at the best way to hook up your TV.
- Consider future video requirements (Will you upgrade to a HDTV plasma or a LCD Panel?) Will you need DVI, Component (476i/p, 780i/p, 1080i/p)
- Audio Requirements, Recomended Power of your current or future speakers. (RMS)
- Current and Future Audio Formats (Dolby Digital ProLogic IIx, DTS ES, DTS Neo:6, SACD, HDCD etc.)
- Quality of Receiver (Brand, Origin of Manufacturer etc.) Best to stick with European Speakers and Japanese Receivers
- Digital-to-Analogue Converters (DAC's) If your budget allows try and find an amp with Texas Instruments Burr-Brown DAC's. Normally found in Mid to High End receivers.
- Audio Interfaces; Optical, Digital Coax etc.
If you'd like to discuss it just add me on msn:
eazy_er_said_than_dunn@hotmail.com
A price range, speaker specs, and the rest of your current system or future system would aid your choice of an A/V Receiver.
marvontherim
Hi James,
Thank you for the information. Here is my situation. I recently mover and I have aging components.
In the new home I have a built in entertainment with 4 NGX 3way flush mount speakers an infinity center speaker and a JBL 10" woofer.
My reciever is about 11 years old a Sony STR-G1ES. My tv is a new Mitsubishi big screen LCD, HDMI compatable. My woofer is creating a loud thumping sound, I believe it may be shot but I don't know and nobody can tell me what is wrong.
The reciever had a coax to transmit signal to the TV but for whatever reason it dosn't. Can't get speakers to work either.
I am wondering if the reciever has gone out as well. How can I determin that?
Thanks
Al
