What to do... Need real help!
N
Nozferatu
Need help deciding what to do with my setup.
DLP56 Samsung.
Denon 3805/3806 (Looking)
NHT m6 l/c/r/
NHT in ceiling 2 pairs center and backs.
Room is 22 x 20 open to another area
ceiling is 12 feet.
total cubic is 9000 plus.
What sub do I use?
It is a great rooom but without enclosure what is proper.
Obviously the bigger the better. But since it is not controlled should I just go for something that works within the sitting area? Can I ignore the rest of the area?
The sitting area is about 5000 cubic. I am 11 feet from the TV.
Do I need a dual 15 earthquake as I am being recommended?
Thanks for your help.
Noz
Mr. Lamb Fries
Mr. Lamb Fries
Whats your budget? It will will dictate what you should get.
N
Nozferatu
budget
I would say around the 2-3k prefer less but I am already considering a $2500 earthquake 15 dual act/pas.
Thanks for the quick reply.
jaxvon
jaxvon
Hmm, I think at that price, I would be looking at a pair of SVS subs.
Perhaps a pair of PB12-Plus/2 subs or maybe a pair of passive SVS cylinder subs with an amp for each one (extra headroom is good).
AVRat
AVRat
You might also consider a pair of Def Tech SuperCube Is.
annunaki
annunaki
Moderator
I would think a pair of PB12-Ultras could be done for under $3K. That would be a stunning Movie/Music setup.
Nice choice of mains. I really liked the M6s.
SVS also offers a dual CS-Ultra package for $2100 here (right sidebar). That should be able to handle a room that size. You can shoot them an e-mail and describe your room to them; they'll help you figure out exactly what it is that will meet your needs. They have excellent customer service.
jack hidley
Can I make the radical suggestion of using the subwoofers that were designed for your speakers, the U1 or U2?
MacManNM
MacManNM
A single PB12-Plus/2 will work fine for you. I can't imagine that you would need more. If you did, then 2 of them will blow away the earthquake you are considering.
