apatel25314
apatel25314
Would you guys get dual ep500's or dual VTF-3 HO Subwoofers with Turbochargers , any other suggestions at all ?
abboudc
it depends...
1. how big is your room and what's your budget?
2. what's the primary application?
More subs can improve the room mode issues with the low frequency sub band, even in smaller rooms. But, without additional help from EQ and or room treatment, it will be a hit and miss proposition either way.
Buckeye_Nut
Unless you're very knowledgeable about acoustic room treatments and calibration, you should be weary of 'dueling' subwoofers, because they can just as easily cancel each other out in an untreated and poorly calibrated room.
Rather than buying two subs, you might want to consider buying 1 sub capable of twice the output.
Unless you have a MASSIVE room, I can't imagine needing more than one HO with Turbo.
apatel25314
apatel25314
thanks, i think i will just get one, and then maybe buy another if bass is lacking
