Hi,
I am finally buying an HDTV and decided to get new speakers (Hsu Ventriloquist) and rewire them to my Denon AVR-3803.
My question is about speaker wires - there are a lot of "high end" speakers that I am little sceptical of. Also, I don't really have a high end audio as you can see from my speakers, etc.
What speaker wires do you recommend that is reasonably priced?
What connectors are more effective - Banana plug or spade?
I have to use flat wires for my rear satellite speakers because of aesthetic reasons that are beyond my control
I assume that I have to use normal (ie, round wires) from the receiver and connect them to the flat wires? Is there any effective way of doing this without degrading conductivity, etc?
My set up is fairly normal: front speakers, center speakers, TV and AV receiver are within 3-5 ft of each other while I assume the cables from the 3 rear speakers to AV rcvr will be about 15 ft. Sub-woofer will probably be within 5 ft of AV rcvr as well.
Thanks for your help.
ssrini
