what size screen do I want
douggreen
OK, my new room built for this, Prewired and ready to go, just got the projector and sharp z12000 (wow). the room is 14 x 21 what size screen do I want? The wall that the screen will go on is 10 tall and 13.7 wide. Thanks
BMXTRIX
BMXTRIX
How close is your primary seating area to where the sreen will be in feet?
Mutiply the seating distance by .667 and that is your maximum screen width that I would recommend.
RLA
RLA
With that projector and a seated viewing position of 14-18 feet back from the screen 106"-110" would be the max I would recommend.
__________________
