What material are you using to mount your speaker crossover components?
I have my components and I bought a couple of three-way crossover boards, but since they aren't made exactly for my crossovers, using them is kind of like pounding a square peg into a round hole. I know there are companies who sell glass-epoxy circuit board material but I can't remember who. I have seen them in all different sizes and would like something fairly thick- about 3mm would be good. If it's perforated, fine, but it's not necessary and if it's plain, it will be stronger because the coils are pretty heavy and I wouldn't want any impact to cause the board to break. The loaded mock-up I have is about 4" x 8".
Another option would be to install grommets on 1/8" tempered hardboard or even solid wood but I haven't found grommets smaller than 1'4" and the flange is 1/2" diameter, which is larger than I want. I can buy turrets and turret board from Antique Electronic Supply but I'm not sure I want to go that way, either. Grommets just seem so much cleaner.
Any help is appreciated.
