What kind of speakers are these?
Q
qwiktune
Is anyone familiar with what speakers these are? The only real identifying mark I can find is the "SR" located on the bottom right of the carpet/cover. Theres also nothing on the back of the speaker itself, but the magnet is squared. I will get more pictures of the back of the speaker if need be, I just wasn't sure if someone might know based of the "SR"
Is anyone familiar with what speakers these are? The only real identifying mark I can find is the "SR" located on the bottom right of the carpet/cover. Theres also nothing on the back of the speaker itself, but the magnet is squared. I will get more pictures of the back of the speaker if need be, I just wasn't sure if someone might know based of the "SR"View attachment 65581
Does not matter what they are. They are junk and need to go in the trash.
They are Sears Roebuck Silvertone speakers. As I said absolute worthless junk.
Silvertone speakers covered a lot of Sears products if you do an image search (and nothing quite like this did I find). Makes me think of SR's (Synergistic Research) level of quality, tho :)
Q
qwiktune
Well worth is relative to each person differently, but my aim was to try and identify them for knowledge sake. Perhaps I run in to them in the future, now I would know what they are or at least the direction to look to identify. Had I asked the worth, then perhaps the initial response would have been more relevant. :)
Thanks, i appreciate it!
They are identical to pictures I found of some Sears Silvertones, but I forgot to post the picture.
I just remembered Sears applied "Silvertone" to a wide swath of things. If you find the photo....
