What kind of JBL etc. bookshelves?
Good4it
Good4it
What model JBL, Harmon , Revel bookshelve speakers would you recommend, under $2000, for front speakers with a sub? I listen to 90% music.
shadyJ
Speaker of the House
Staff member
You can't go wrong with anything from Revel. I wish Harman would do something more with Infinity. Maybe a improved line of Primus speakers or high-end speakers like Infinity used to make. You might also look at a pair of JBL LSR4328 if you want to stick with something from Harman in that budget range.
I listened to the Revel M106 I believe it was, maybe 105, and they were excellent.
speakerman39
speakerman39
If you bought the BMR's, you wouldn't need to bother with a sub for music.
Well, you have a point. But some with preference for music listening still use a powered sub. I am one of them. John mentioned the Philharmonitors which is an excellent choice. But, since the OP specified under 2K I recommended the BMR's as well. There are lots of folks that don't use a sub when listening to music. So you do have a point here.
Cheers,
Phil
charmerci
charmerci
depends entirely on the music you listen too.
I have the New Phils. (That photo on DM's website is mine actually.)
For music, I recommend the BMR's because they go lower with a 7" woofer rather than the 5.5", plus it dispenses with the mess of sub integration/inconvenience and placement.
shadyJ
Staff member
I can only say I would not be happy with such speakers without at least a couple of serious subs to back them up. Much of the music I listen to has a lot of low frequency energy.
speakerman39
speakerman39
I like my bass too. Especially, the kick drums! Want it ti hit in a dime and stop on a dime. Tight and punchy just the way I like it! Oh yeah!
Cheers,
Phil
charmerci
charmerci
As much as I love bass when appropriate, there are some songs/recordings that I play in which there is too much bass. To each their own!
