so i was just testing out a speaker that i made, and it wasn't doing anything so i turned up the volume and nothing happened so i turned up to max and the voice coil started to smoke so i unplugged the speaker and i left my room to throw it out and when i came back in my receiver was making a high pitched tone so i turned it off and it stopped, i turn it back on again and it good but then after it was on for a minute it beeped once and continued to function normally. so what happened to it, did i blow one of the channels? it didn't go into protect mode so i don't know what happened
What was that speaker and what was the crossover circuit?
You had no sound, but the receiver was sending a lot of power to the speaker as the voice coil smoked. If the receiver had DC off set, and the protection should have stopped that, the receiver would not work now.
So I think you had a circuit that presented a strange highly reactive load to the receiver and sent it into a supersonic oscillation. You are lucky that receiver works, but it may yet be damaged.
I suspect you need a lot of guidance with your builds. I think you need to publish the details here for review before you connect up anymore of them.
Kids need mentors. I was lucky in mine.
