What is the purpose of the dolby home theatre software?
jack01
Dolby Home Theater v4 PC Audio
Is this JUST for the internal built-in laptop speakers to be optimized (as http://goo.gl/emQx5 seems to suggest)? It doesn't seem work when i plug in my onkyo (HD22HDX) speakers through HDMI but it does work only for the built-in speakers.
Is there any other software that is recommended to equalise and enhance sound for music/film (i have found generic ones)? I would like to use 5.1 surround sound...
Cheers!
Trev
Would make sense to me to let the Onkyo take care of that...
I'm not knowledgeable enough to stack different EQ settings across a process chain. Preference is to let the device that can handle EQ best, take care of the works (for me) - especially when passing audio over HDMI. Would ask are you primarily concerned with music, or films?
In which case... I'll say that rather than concerning oneself with a utility that runs in the background, most 'player' applications will EQ things better than a terrible Dolby, Realtek, or whatever background utility. Jriver worked really awesome with my PC to HK. Foobar is solid too. For films I use PowerDVD 12 passing PCM to the HK to be taken care of. I don't let my PC do any decoding.
Your call. Hope what I spat here is accurate. I'm no pro and I'm sure 12 other dudes on here can offer up better advice.
Regards,
