What is the best media server for PS3?
Hittdog
What do you guys find is the best media server for PS3 for streaming music, video, and pictures from a PC?
GlocksRock
GlocksRock
I also use PS3mediaserver, as well as Twonkymedia
bmurphy2121
How do you stream music and movies through your PS3? I know rhis is prob a dumb question but I'm not sure how to do this and would like to.
GlocksRock
GlocksRock
With a media server such as Windows Media Player, PS3mediaserver, twonkymedia, TVersity, ORB, etc...
bmurphy2121
Ok does that mean you use the media player and the others mentioned playing on your computer and then hook it up to your PS3 so that it can play on tv?
Sorry I the question is dumb but im not much of a computer guy and how to do all this. If there were more instructions i could do it just not real computer savy thats all.
GlocksRock
GlocksRock
You install the media server on your pc and your PS3 will see it and play whatever files/folders you allow on the server.
bmurphy2121
So you install one of the mentioned apps above on comp, got that part. So how does my PS3 see it? does that mean i can listen to my sirius music through my PS3 and other stuff?
GlocksRock
GlocksRock
not siruis, well maybe with ORB, but your PS3 will find servers automatically.
caper26
caper26
just install PS3 media server. It is easier to figure out than WMP, plus it allows all folder access. After you run the server, go to your PS3 XMB and pick music or video or pictures...scroll down until you see the PS3 media server icon and click on it...then browse through your PC's folders as you would with windows explorer. The only note here is that you can only select the type of file which corresponds to what heading you are under in the XMB (ie, you cant select a video file if you are under MUSIC in the XMB)
sansae
hi there,
Xbox 360 Elite, PS3 Slim is best network for ps3
