What happens in settings in Denon Receiver?
Old Onkyo
Old Onkyo
So....on a Denon 4500, when I run Audyssey app and send the results to the receiver, make adjustments get the sound like I like, if I do not save the results to a Quick Select button, are those settings saved?
if I am listening to a new Audyssey imported setting, and I go to a previously saved version on quick select, how do I get back to new settings I was listening to?
thanks for any help. The question is clearer in my mind.
L
Leemix
Quick select has nothing to do with the audyssey app setup. After sending the data from the app that is what the AVR is using. You can change the settings in the AVR to your preference after receiving the setup but the audyssey app wont know that.
You cant store multiple “audyssey runs” on older AVRs but you can save them to a memory stick. (And load)
Quick select only saves a few things to quickly select a preference, like input source, main volume and audyssey on/off. There may be more but thats the gist of it.
