L
Leal
Im runing wires from my TV to a closet where i will have my equipment. This is the only chance i have to run wires because of remodeling, no chance to repull wires after this. What else do u guys think i need?
These are the wires that im runin right know.
TV to closet
2 HDMI cables
2 coax
1 cable that has red white green
1 one wire for my fish eye
What else should i run?
phlakvest
phlakvest
Any chance you can run a 1" or 1.5" conduit when you have everything open so you can make changes later if you have to?
What do you have in the closet that you are trying to hook up to the TV?
TV to closet
2 HDMI cables
2 coax
At least one Cat5e everywhere you drop cables to and maybe a 4 conductor speaker cable. Better now than trying to do it later.
What kind of cable is the Red/White/Green?
L
Leal
I have nothing in the closet, that is where i want all my setup to be?
DVD, Reciver,cable box, fish eye, what else is there to put in?
L
Leal
These are the cables ive been told to run.
2 HDMI
2 Coax or RG6
1 telephone or 4 conductor wire
1 composite or dubbing
Please let me know what u guys think.
Remember i have one shot and one shot only to run wire before i close the walls. I have no attic.
3db
3db
Good thinking. :)
I have no idea what this is.
It's 2 Cat5e cables, which can be used to IR control, future RS-232 control (it's the best way but not much consumer equipment actually uses it). Audio and video can be sent over Cat5e, too- even HDMI. If you can't install some kind of conduit, you'll need to run more cabling than you probably need. To keep it more simple and cut the initial cost, I would do the audio/video switching at the source end. That way, you'll need one main video cable and maybe speaker cabling, if you have LCR speakers around the TV location. If you use the TV's speakers, HDMI should cover that but it's still problematic, at this point. Installing a 2" orange conduit is the best way to keep from being in a position where you need cabling that isn't practical to run. Just don't run it in a way that has frequent or tight bends. Gentle curves makes it much easier to run cables.
Rickster71
Rickster71
Do you have a basement, or crawl space? You could vertical conduit runs up to your closet, and behind the TV.
Depending on your equipment; I'd run at least two dedicated 20AMP lines to the closet.
Also, a dedicated 20 AMP circuit, to where the sub will be located.
