Drummerboy said:
this is what all have for my first forray in home theater :
Pioneer VSX1015TX reciever
Polk RTI 8 fronts
Polk RM6600 satellites(4) and center for rest of 7.1
Polk PSW505 sub
(soon to upgrade to CSI3 center channel, the RM6600 one is to small with 3 and 1/8 drivers i think)
This goes in a 13x14 foot room.
whadoyathink?
It's a real nice system for your smallish room.
The Pioneer VSX1015TX reciever is a great bang for the buck piece and should be powerful and adjustable enough to fill up your room with plenty of high quality sound.
I am one of those who likes the rti8's balance better than the rti10's or rti12's but they definatly need a sub.
I would like the rti4's as surrounds better but I am guessing you already have the RM6600 system. The fact that you have very small surrounds saves amp power for the power hungry rti8's just make sure you set up the receiver correctly to save all that power.
The center upgrade is a must IMO to match the rti8's better. The center is the most important speaker for home theater.
As for the sub, you could do better for the money, but it's not a bad sub, and if you like it that is all that matters. It will be plenty loud in that size room!
Check out the subs Leprkon suggested and I would also add Athena, Energy, Paradigm, Definative Technology...and what ever else you stumble across.
SBF1
