What do you think about Behringer B2030P for Home Theater use?
Y
yacpro13
Hi all,
like the titles says, I'm considering buying a pair of Behringer B2030P. I was more leaning towards the Infinity P162 earlier, but figured they were a little on the heavy/large size to be wall mounted (my speakers will be wall mounted).
So the B2030P's are getting rave reviews everywhere, but I seem to read they are Near Field (I think that's the right term) studio speakers.
My question is, would they be an appropriate choice for a home theater?
These don't have a center model, so I guess I would get a pair for Right Left only, and add a center and surrounds later on (want to build this system over time). Speaking of, should I be concerned if the speaker brands are not all the same? What Center/Surrounds would you recommend to go with B2030P's right/left speakers?
Here's the potential setup:
B2030P right/left
Denon AVR 391 receiver
1 or 2 subs (later)
Center & surrounds (later)
Thanks for your input!
Sam
zieglj01
zieglj01
They are nearfield - how far will you sit back? Also, the front 3 channels
need to be voiced the same. You may need to find a way, to use a 3rd
one as a center channel. Some people may reccomend a phantom mode
for the center voicing.
KEW
KEW
From wikipedia:
Monitor vs Hi-Fi speakers
While no rigid distinction exists between consumer speakers and studio monitors, manufacturers more and more accent the difference in their marketing material. Whereas in the 1970s the JBL 4311’s domestic equivalent, the L-100, was used in a large number of homes, and the Yamaha NS-10 also served both domestically and professionally during the 1980s, there are no present-day equivalents. Professional companies such as Genelec, Klein and Hummel, Quested, PMC, and M & K sell almost exclusively to the professional monitor market, while most of the consumer audio manufacturers confine themselves to supplying speakers for the home. Even companies that straddle both worlds, like Tannoy, ADAM, Focal/JM Labs, surrounTec, Dynaudio, and JBL, tend to clearly differentiate their monitor and hi-fi lines.
Generally, studio monitors are physically robust, to cope with the high volumes and physical knocks that may happen in the studio, and studio monitors are used for listening at shorter distances (e.g., near field) than hi-fi speakers, though nothing precludes them from being used in a home sized environment. As well, studio monitors are increasingly self-amplified (active), although not exclusively so, while hi-fi speakers usually require external amplification.
Many inexpensive hi-fi models are designed to make a pleasing sound by deliberately manipulating the frequency response curve of the audio signal they receive. No speaker, monitor or hi-fi, regardless of the design principle, has a completely flat frequency response; all speakers color the sound to some degree. The 'monitor' speaker is assumed to be as free as possible from coloration.
http://en.wikipedia.org/wiki/Studio_monitor
Alex2507
Alex2507
I'm considering buying a pair of Behringer B2030P. I was more leaning towards the Infinity P162 earlier.
Either is a decent choice. With the 2030P's you can simply use a single 2030P for the center. They are so cheap that it pays to just get 6 of them for a 5.1 system and leave one of them packed away as a spare. I have put together a system with 3 of these for a front sound stage. They absolutely need a sub and have no grills.
The Infinity Primus line has a couple of choices for a center channel. I have the PC350 but wish that I had gone with the smaller 2-way option of the PC250(?). If the 162's are too big you might consider the 152's. The 152's are reputed to have some advantage in the midrange IIRC. I'm happily using some as wall mounted surrounds. These go a little lower than the Behringers and look better because of their grills.
sholling
sholling
B2030Ps are near field monitors but work fine as bookshelf speakers in small to mid-sized rooms - as long as you have a subwoofer for anything below 80hz. The only real problem is that they're homely and you'd have to use a 3rd for a center - should you choose to have a center. Part of the advantage of the B2030Ps is that 6 months ago you could buy them for $110-130/pr shipped and that made them a heck of a bargain. Now they sell for $150-200/pr making Infinity's P162 (comparison) a better looking option. The now discontinued P162s can still be found for $170/pr shipped. The matched center is the PC250 ($150). Go with the One
shadyJ
Speaker of the House
Staff member
Both the Primus and Behringers are terrific speakers. I have the 2031p and Primus p162, they both sound great, you can't go wrong with either. If you go with the Primus speakers, go with the c350 center, I have heard it is much better than the 250, and my 350 is a killer center. Some other speakers in their price performance range are the Ascend Acoustics CBM170s and the Hsu HB-1 speakers, although those are a little bit more expensive.
If you wall mount, check out the Pinpoint AM40 side clamping wall mounts, they can hold up my 16 lbs speakers with no problem and they don't even require you to drill a hole in your speakers. A little expensive at $60, but well worth it. I tried a cheaper bookshelf speaker mount from monoprice which was supposedly rated for 30 lbs and they were terrible, learn from my mistakes and just spend a bit more to get the AM40 mounts.
Y
yacpro13
Thanks everyone for the useful input - I will try to respond to some of your questions/comments.
It's a little hard for me to decide because like I said this is my first HT system. I guess in the end if I can beat the Energy Take Classic set, then I'll be happy.
I will be sitting at about 8 feet from the TV. The room is a living rm / dining rm / kitchen open area. Usage is probably 60/40 music/tv.
Unfortunately, the P162's are out due to their large size as the speakers must be wall mounted (and I find it odd to mount such a large speaker next to an LCD TV). I like the sleek looks of satellites, but I think I'll get much better sound from either of these speakers; am I right?
Now I'm depading between the P152's and the B2020P's. The thing pulling me towards the P152's is the availability of a center speaker (ie. better HT integration), whereas I'd have to use 3 Behringers if I go with those. On the other hand, as I've mentioned, the B2030P's are getting amazing reviews.
I'm honestly torn.
PS: Note that I'll be using the system as a 2.1 for a while, then probably move these speakers to the rear and get new fronts+center.
Thanks for your time!
