What do I need to do?
jkirksey1889
I have a yamaha 5.1 receiver and of course have a 5.1 set up. Center speaker, 2 fronts and 2 rears and a sub woofer. When watching a movie, at times, especially if the characters are whispering or talking in a low tone, I have to turn the volume up to hear what they are saying. Then when the action part of the movie starts I have to turn the volume down because it's too loud.
The receiver has the auto calibration tool and I have done that.
Will a better center channel work better for me? Is it just the way it is?
Thanks.
adk highlander
adk highlander
Sith Lord
How many times did you run YPAO? I have found with Audyssey that I will run it with a variety of mike positions until I get the best results.
Go in and check the speaker distances and trim levels of each speaker. If the distances are way off or the center channel is adjusted well below the other speakers you could make adjustments there.
Also get a SPL meter and do a manual setup and see if that helps.
njedpx3
njedpx3
Center Channel = dialog
First try what ADK said run you Audessy at diffferent listening points. And I agree you can manually set with a SPL meter, Radio Shack has a decent analog or digiatl meter for $49.99
YYou haven't mentioned what your AVR is; have you tried different sound settings?
You are corrrect the dialog comes out of the Center channel. You could replace the center channel with a better one or one that is matched to the front speakers to maintain timbre; seamless front sound.
Probably the easiest fix to try is just to increase the gain to your center speaker; Audessy is not always perfect, especailly when it comes to dialog.
Peace, Good Luck and Good Sound,
Foreset Man
jkirksey1889
Thanks guys.
Yamaha rx-v467
I'll play with it some.
jostenmeat
Thanks.
First of all, consider the position/location of your center speaker. If it's too low and not angled toward your head, remedy the situation with mopads or doorstops, etc.
If the speaker is buried inside a shelf, or even pushed back from the lip of an AV cabinet, please pull it out as comfortable as possible, even if protruding from lip.
Next, bump up your level in the center speaker by, say, 2db or so.
If still not quite good enough, look toward your receivers (and various sources) to play with various DRC (dynamic range compression) settings. They also may be called something like Late Night settings. In the future, I finally might advise looking for features set as Dolby Volume and the like.
If none of the above works, I would look at your acoustics and listener positioning as well as the speakers themselves. Actually, you should do that anyways.
I don't know about YPAO, but with Audyssey, the very first position determines all of the distances and levels, therefore it should be smack in the center of the viewing area. After that, all the way to the 8th position or beyond, it can be anywhere without affecting said distances (and levels, so far as I know).
Davemcc
Davemcc
Sometimes, first reflections can muddy the sound. It's kind of like an echo that makes the voice less distinct. You can put some sound absorbing material directly behind the center channel and see if that helps.
If the room in general is highly reflective, sound absorption in other key areas can also help.
