What can I get with this budget?
N
newaudiofile
Guys,
I'm looking for a projector with a budget of €700 (approx. $1000)
I do not have a dedicated HT room so I guess light contol could be a problem. I just thought this is a useful information.
I appreciate all the help that i can get.
jcPanny
jcPanny
Front projector
Check out projectorcentral.com for more projector reviews and information.
In your price range you can probably find a pretty good 720p HT front projector, but you would probably need to double your budget for 1080p.
E
Exit
I think the projector guys probably hang out in the projectors and screens forum but maybe they look in here too. You might get better responses in that forum.
patnshan
patnshan
I have a panasonic AX100U, the 200U is the new model and would almost fit in your budget. It is a nice bright projector which I have had no problems with.
Pat
N
newaudiofile
Pat
the AX200 has been recommended by someone too. But a little out of my budjet. But I'm still considering it. Thanks
