What banana plugs to use with Blue Jeans speaker cables...
Not too bad of a price for locking. They're all just connectors though, so I wouldn't say you need to go fancy on them. I like the 091-330 bananas from Parts Express .com They are side exit (less strain on the wire) and they use a small pellet as a buffer between the wire and the screw so the screw doesn't damage the wire as you tighten it. These are the same ones that Bluejeans sells on their site...
RH Customs
Those are nice but I currently only need four pair. So I think I will stick to the ones from DIY Audio, and also I need to decide on what type of techflex to use. I know I will use the PET Techflex, but I can't decide on what color or pattern. I don't want them to just be balck.
RH
